Barry Webb
Posted: Tue May 10, 2016 6:05 am Post subject: Hitachi drive problem |
Hello I have just received and fitted a new set of belts to my VIP 202p player and have a problem with the disc eject the disc goes in ok and plays but when you press the reset the disc only starts to come up a little why I have tried taking the weight off the drive by lifting the disc and it works fine it just cant take the weight of the disc is there any adjustment on this or could it be the belt is wrong.
Barry. |
Barry Webb
Posted: Tue May 10, 2016 7:11 am Post subject: |
| Hi sorted it was the new belt I looked at one I did last year and the belt sent this time is twice as thick putting to much load on the motor. |
Posted: Tue May 10, 2016 8:50 am Post subject: |
| This is a pretty common problem on the Hitachi style machines. I am actually having the same problem with one of mine. The most common problem that causes this is the little tooth clamp that holds the rod for the pully wheel will crack or even break off. I had never heard of too thick of a belt. I might have to try that on mine. Where did you get the thinner belt from? |
Barry Webb
Posted: Tue May 10, 2016 10:49 am Post subject: |
Hi I got the first belts from Tom and they were a lot smaller than the set he just sent me . I think the new belts were to tight and put to much load on the motor when lifting up the carriage and disc as I say the first set of belts I had over a year age were much thinner so less load.
Barry |
cedwaechter
Posted: Tue May 10, 2016 3:47 pm Post subject: |
| It depends on if the Hitachi model is a later model or an earlier one. The belt size on the older models each take a different size. The later models take 2 belts that are the same size. Later models are a lot lighter than earlier ones and the platter mechanism is different. See if this works or helps. |
