Posted: Fri Jun 28, 2013 10:35 pm Post subject: SJT400 Stylus Height Adjustment |
| Ok so apparently there is a way to adjust the height of the needle on a SJT400, anyone know how? When I got my 400 the needle wouldn't read anything so I took the stylus from my 200 and that worked just fine but would start about 6-12 seconds in on both sides. I was told that trying different stylus's could fix that. Well I took the stylus from a 100 and it wouldn't read at all either even though it worked just fine on the 100. I was puzzled. I emailed John at CEDatum and he suggested I adjust the height of the stylus. I will ask him how if nobody here knows but I just thought I'd post this if anyone else has the same problem. I searched and found nothing about the topic so here it is. I also had John check the original stylus I got in the 400 and the result was that it was an A- stylus in working order so there's no reason it shouldn't have worked in my 400. Any help is much appreciated. Thanks. |
Posted: Sat Jun 29, 2013 6:42 am Post subject: |
I've never heard of a stylus height adjustment, but have had to adjust the turntable height sometimes to get the stylus to work properly.
The turntable does have a specific length for the stem to be, but in general, it has to sit about 1/32 of an inch above the panel underneath. This topic covers that adjustment:
http://www.cedmagic.com/tech-info/repair-solutions.html#dragging-turntable
But it doesn't cover what happens if the turntable is set too high. What I've seen in actuality is that the stylus will not operate properly and you get no play in that case. This is probably worth looking into.
I'd adjust the turntable downward until it starts to scuff against the bottom panel, then I'd follow the instructions to move it upwards 1/32 of an inch, and see if it played then.
Something interesting about your situation is that one stylus did manage to work. I too have seen this even with turntables set too high, but the sound and picture are of a lesser quality than they could be. |
Posted: Sat Jun 29, 2013 5:21 pm Post subject: |
| A few years ago John of CEDatum gave me a special stylus that he had made that had a extra long fly lead to use on a turntable that was adjusted to low. I never had a chance to try it out cause I didn't have a player with that condition. I tried it on one of my Toshiba players and it didn't work very well because the turntable height was correct. |
rabika
Posted: Thu Jul 04, 2013 2:19 am Post subject: |
It includes the 12-page CED-size brochure and sub-displays on microprocessor and groove technology. The column of four CEDs are the foam store displays rather than real discs.
Here's a closeup of the microprocessor display:
gamesmagzine
DELETED
techmagzine
Posted: Thu Jul 04, 2013 7:59 am Post subject: |
| rabika wrote: | It includes the 12-page CED-size brochure and sub-displays on microprocessor and groove technology. The column of four CEDs are the foam store displays rather than real discs.
Here's a closeup of the microprocessor display: |
Sorry but what are you talking about? |
Posted: Thu Jul 04, 2013 9:03 am Post subject: |
| Rixrex wrote: | | rabika wrote: | It includes the 12-page CED-size brochure and sub-displays on microprocessor and groove technology. The column of four CEDs are the foam store displays rather than real discs.
it appears to be some sort of bot that copy/pastes stuff that tom says? _________________ (2)Sears 274 & 934(80150,10&11350), sft100, sgt250, sjt 090-400, vp550, VDR3000, VP2000 & 4000
Dude111
Posted: Thu Jul 04, 2013 5:59 pm Post subject: |
| rabika wrote: | | Here's a closeup of the microprocessor display: |
Welcome...... You forgot to include a picture of it! |
Posted: Sat Jul 06, 2013 8:24 pm Post subject: |
| Apparently you are correct Rix, I pulled the platter off and the thrust washer was missing. Also like I had been stating before the rubber or foam padding around the edge of the platter was missing, these are most likely the cause of my stylus not reading the disc. I've ordered a replacement thrust washer and turntable complete with padding and will have a go at it once it arrives. Can't wait to get my 400 working again. |
Posted: Sat Jul 06, 2013 8:57 pm Post subject: |
| ketonic_dude wrote: | | Apparently you are correct Rix, I pulled the platter off and the thrust washer was missing. Also like I had been stating before the rubber or foam padding around the edge of the platter was missing, these are most likely the cause of my stylus not reading the disc. I've ordered a replacement thrust washer and turntable complete with padding and will have a go at it once it arrives. Can't wait to get my 400 working again. |
the thrust washer wasnt stuck to the magnet or flung off somewhere? dang dude u had a double whammy _________________ (2)Sears 274 & 934(80150,10&11350), sft100, sgt250, sjt 090-400, vp550, VDR3000, VP2000 & 4000
Posted: Sun Jul 07, 2013 8:54 am Post subject: |
| Yes, I usually find it stuck to the magnet on the turntable underneath. |
