blindfury420
Posted: Thu Sep 01, 2011 1:42 pm Post subject: j/k play problems |
If the function belt is new and motor works and it loads and unloads the ced, but will not play, even with a known working stylus and stylus arm does move but display shows only -- is that cause one of the buttons is mashed completely down and stuck?
I kinda remember cedatum talkin about this and I even think beetle's 300 had this problem.
btw the only buttons that I can tell work are reject and power. _________________ I dont own
McMicheal 5001h
Hitachi VIP202P
JCP 686-5705
RCA SKT265, SKT300
RCA SJT400X, SJT425 |
blindfury420
Posted: Mon Sep 05, 2011 10:10 pm Post subject: |
Anyone? Any ideas? Did your player do this beetle or was it stuck in pause when buttons were broke and stuck on? _________________ I dont own
McMicheal 5001h
Hitachi VIP202P
JCP 686-5705
RCA SKT265, SKT300
Posted: Wed Sep 07, 2011 8:39 pm Post subject: |
Ryan, I would shoot John an email, it does sound like my 300. I got it back today!!!! (he held it for me until we got moved! I havent even opened the box!!! I have no doubt about it playing though, He does excelliant work!!! Soon as i get settled, i'll be going to work on my SFT100. You going to semd me the "how to" video:).
Good luck, my young friemd!!!!! _________________ SGT-250
Posted: Sun Sep 18, 2011 5:10 pm Post subject: |
Fury, were you ever able to get that SJT 200 to play? Meaning the one that displayed the double dashes no matter what you did.
If so, what was the problem? |
blindfury420
Posted: Sun Sep 18, 2011 5:28 pm Post subject: |
I'll have to look back at the email but im pretty sure its something i have to replace and solder. I got busy tryin to figure out an easy non solder way to replace coil in arm stretchers of j/k models. I figured out a way to do that and it reduced the wobble in my 400 that had wobble in video haha gonna try a different turntable soon and adjust height or what not. I will get back to you on the double dash 200 though! _________________ I dont own
McMicheal 5001h
Hitachi VIP202P
JCP 686-5705
RCA SKT265, SKT300
Posted: Sun Sep 18, 2011 6:55 pm Post subject: |
Regarding turntable, 1st check out these things:
Is the flat spacer/washer still located at bottom of turntable shaft between shaft and adjustment screw or did it fall out in transit and maybe got stuck to the magnet? I had this happen once and turntable wobbled until it was back in place.
Also, how is turntable where it attaches to the stem? Is it solid or loose? Are the tines that hold turntable in place on the stem sloppy or tight? One player I had was sloppy at this connection causing it to sometimes vibrate oddly and scuff occassionally. and I did some "tightening up" on the tines and solved it, then locked it in place with a dab of silicon (because you can remove silicon pretty easily if you want). |
