Nokes
Joined: 19 Jun 2010 Posts: 11 Location: Alliston, Ontario, Canada
Posted: Mon Feb 06, 2012 8:56 pm Post subject: What's wrong with my 'shiba? |
I have recently fixed my dad's old Toshiba VP100, brand new belts and drive pulleys. Most of the time, it reads a disc no problem, but sometimes, it just doesn't pick anything up, but after leaving for an hour or so, it's ready to go again.
Is this a common problem?
Can I fix this? How?
Thanks in advance |
Posted: Tue Feb 07, 2012 5:24 pm Post subject: |
personally I have had 3 toshiba's, 1 wards, and 1 elmo, all clone/shiba player's go through my hands and I have never seen that problem. I wish I knew but I can try and help ya
What exactly happens when it stops working? Does the turntable still spin? Does the stylus arm move? What does the LCD display do when it stops working? Have you tried another stylus? _________________ I dont own
Nokes
Posted: Wed Feb 08, 2012 10:31 pm Post subject: |
It keeps spinning, I don't think the Stylus arm moves, the LED display shows "- -" as if it's still loading, I don't have any other styluses to try. _________________ Toshiba VP-100 est Tres Magnifique! |
rideauwrangler
Joined: 07 Feb 2012 Posts: 46 Location: Ottawa, Ontario
Posted: Thu Feb 09, 2012 7:48 am Post subject: |
| I also have 2 shiba's in my stockpile and neither of them work. I'm going to try to figure things as I really want them working out but I may pick your brain on your experience with these players... |
Nokes
Posted: Thu Feb 09, 2012 9:21 pm Post subject: |
I'll help as much as I can, but Last time I saw this machine working properly, I was learning to walk _________________ Toshiba VP-100 est Tres Magnifique! |
Posted: Fri Feb 10, 2012 1:40 pm Post subject: |
| Nokes wrote: | | It keeps spinning, I don't think the Stylus arm moves, the LED display shows "- -" as if it's still loading, I don't have any other styluses to try. |
Pull the top off and look at the tracking arm. In a free state the arm should be perpendicular to the guide rods or rod. you can check it with a square if need be. I have had this happen to two Toshiba players. During shipping or just a good jolt the arm is so flimsy that the arm gets bent so that when the arm moves to the disc the stylus drops and it doesn't pick up a signal. The stylus automaticly retracts back up and the turntable continues to spin and the display shows "--". I gently bent the arm back to square and that cured the problem on both players. |
Nokes
Posted: Sun Feb 12, 2012 5:17 am Post subject: |
Thanks, I'll try that and report back _________________ Toshiba VP-100 est Tres Magnifique! |
