Posted: Sun Jun 02, 2013 6:04 pm Post subject: SGT-250 stuck on -- Help! |
| I bought an SGT-250 that needed a stylus. I popped the stylus in, (actually tried 2 different ones) but the player just sits at the 2 dashes (--) It won't take off. Can anyone give me any ideas? Thanks! |
Posted: Sun Jun 02, 2013 6:51 pm Post subject: |
hey buddy i found this, maybe it will help?
Player Category: F/G Chassis Fault: Defective 15 Volt Regulator
Symptom(s):
Loading indicator "L" flashes slower than normal and the display indicator may stay in "--" mode permanently after a disc is loaded and the player attempts to initiate play. Pickup arm may suddenly run forward without any buttons being pushed.
Solution(s):
This indicates a weak 15 Volt regulator inside the player. The regulator is designated U3801 and is a 3-pin integrated circuit attached to a large heat sink at the corner of the PW3000 circuit board just behind the ventilation duct on the back of the player. The voltage between the center ground pin and the right V_out pin should measure 15V +/- 0.6V. If less, replace the regulator with industry standard equivalents LM7815CT, NTE968, ECG968, or SK3593. _________________ (2)Sears 274 & 934(80150,10&11350), sft100, sgt250, sjt 090-400, vp550, VDR3000, VP2000 & 4000
Posted: Mon Jun 03, 2013 7:44 am Post subject: |
That's a possibility, and another you want to check out, which is more common, is the stylus set down adjustment, seen here:
http://www.cedmagic.com/tech-info/repair-solutions.html#improper-stylus-set-down-adjustment
I find this a problem in many players left to sit a long time. There's an easy test described in the "symptom" notes on how to determine if this is it. You just have tobe sure you have a good stylus in the player when doing the test. |
Posted: Tue Jun 04, 2013 7:25 am Post subject: |
| I think when I had brought mine in and it had the two dashed John said that was a trouble indicator. Mine would play but only in black and white and with no sound. Did you check to make sure neither of the belts are slipping. I know the belt in the back can wiggle it's way off and then your arm won't load into the play position. Other than that you could ask Ryan, maybe he's experienced that before. Best of luck with it. |
Posted: Mon Jun 10, 2013 6:44 am Post subject: |
I've had players display the double dashes, and be playing with poor video/audio and in B&W, or slipping between B&W and color. When this happens, I remove the belt and leave it in pure ammonia overnight, as that will shrink it slightly and takes off any oils.
Then I clean the turtable belt shelf, where the belt grips, in order to get off any grime or oil that may have collected there. Before returning the belt, I check the motor adjustment screw closest to the left corner for snugness. Sometimes this screw is a tiny bit loose.
Then the belt gets dried well and goes back on. I've had very good success doing this for players that exhibit slipping belt symptoms. |
Posted: Mon Jun 17, 2013 7:11 pm Post subject: |
| Thanks for the advice Josh, & Rick, I tried to adjust the stylus, either that didn't work, or I didn't adjust it far enough. I also tried putting a disc in, and tuning the power off, sliding the stylus are up and turning the power on, and I still got the -- |
Posted: Mon Jun 17, 2013 8:29 pm Post subject: |
| Guys, I have been monkeeing around with my player, and I popped a disc in, and still had the "--" and I was checking the belt in the back, I can't think of the name, it has been a long day, the belt in the back that advances the stylus arm, I rolled the gear to advance the arm, and then, all of a sudden, the -- turned into 36!!! I didn't have it hooked to a monitor, I was just trying to see if I could get the "0" on there. When the numbe was on ehreh the rapid access started working! It would advance the disc or take it back, the stereo light indicator flashed too. When I stopped advancing it, unfortunately it just stops there. I am thinking like Josh said, the belt is slipping badly. At least that is what I think. |
Posted: Mon Jun 17, 2013 10:26 pm Post subject: |
The belt will neither advance nor reverse if there's no minute number displaying. In other words, the stylus isn't reading the disc because either the stylus is in poor shape or the turntable drive belt is not at proper speed and/or is slipping.
Exact same thing happened to me about 2 weeks ago, and I checked the stylus as being okay with another player, so the culprit was the turntable drive belt slipping. A clean up as I stated above solved the problem. At the same time, I cleaned up the advancing belt too.
One last item that can cause such trouble, but is unusual, is if the stylus is askew or is not perfectly perpendicular to the platter. This can be checked by letting the stylus tip hang loose on the "fly-lead" wire and see if it droops to the left or to the right. If not, it's okay. If it does, then a slight turn of the pivoting rivet holding the fly-wire will straighen it out. But if you don;t know what I'm talking about, best don't try it. |
Posted: Tue Jun 18, 2013 5:42 am Post subject: |
| But when I manually roll the stylus arm towards the middle of the disc, each time I have done it, (about 5 different times) the double lines (--) turns to the number 36. Now I didn't have the player hooked up to a monitor at the time, I will try that today, but, like I said, when the number pops on, the stereo light comes on, and the buttons work on the player, fast forward, reverse, random access. Before I tried this, I could hear the little motor whirring, but the belt wasn't moving, so wouldn't it be best to change the belt first? Also, when the number 36 came up, random access would take the stylus arm all the way back to 01 (but not to 0). The stylus is a good one, no problem there. |
Posted: Tue Jun 18, 2013 7:56 am Post subject: |
Yes, that's the right way to go, try taking care of the advancing belt first, before the turntable drive belt, however you should first take a look at the landing latch adjustment here:
http://www.cedmagic.com/tech-info/repair-solutions.html#landing-latch-misalignment
Then if you move on to the advancing belt, first use the CEDatum method of belt shrinking before just putting on a new belt. You can see their tips on thet here:
http://cedatum.com/15322.html
It actually works pretty well, but you need to clean the belt pulleys well with some alcohol before returniong the belt to position.
Then after those two fixes, if it still won't work properly, you go to cleaning the drive motor belt. |
