prg222
Posted: Tue Dec 10, 2013 8:19 am Post subject: Problem with SGT-250 |
I have 3 CED Players. One works well. Another I have not fired up in a few years it had have some problems.
I got a nearly new 250 player. The lady said it stopped working so they put it back in the box (in 1985)and wanted to sell it. I got it for $15.00 plus some discs.
All it needed was the load belt in the front right hand corner.
I had no problem with it for a few months. But now when I load a disc the L symbol comes on when powered up. The disc begins spinning, but I get two dashes on the display (__) The controls on the front Rapid Access Search will not respond. on the front of the player or from the remote.
I tried changing the cartridge. But that did not solve the problem.
I did put the working player next to the non working one. When a disc loads and begins to spin on the good player. One can hear a sound just before the disc begins to play. It does not happen on the other player.
So could it be a mechanical problem? Or more likely an electronic one?
Any help would be appreciated |
Posted: Tue Dec 10, 2013 8:26 am Post subject: |
Are you sure the stylus you tried is also good? If not try the stylus from the good player. _________________ SGT-250
prg222
Posted: Tue Dec 10, 2013 8:39 am Post subject: SGT 250 problem |
| I tried swapping the cartridge from the good player. The same two dashes show up and the arm holding the cartridge does not start to advance, as it does on the other player. |
Posted: Tue Dec 10, 2013 9:22 am Post subject: |
If you only get the two dashes, that typically means the stylus is not reading the disc in order to send a signal to start the display properly. This could be a mechanical issue, but also sometimes is within the electronics.
A mechanical issue could have to do with the landing latch, the stylus set down, the servo belt or the turntable belt. Suggest you review the CEDmagic repair solution to see if you can locate one that fits the symptoms:
http://www.cedmagic.com/tech-info/repair-solutions.html
If in the circuits, the stylus might be reading the disc, but there's no proper signal to activate the display and the stylus advance. Circuitry issues are usually tough to figure out unless you have a good electronics background. Always run through the possible mechanical solutions first as those are fairly common. |
Joined: 28 May 2004 Posts: 576 Location: Sacramento, CA
Posted: Fri Dec 13, 2013 2:15 am Post subject: |
I've got an SGT-250 like that too- worked when I got it, hadn't been used much and did that when I tested it later. Someone said it might be an IC. _________________ Videodisc and stereo sound- there's no better value around! |
Posted: Fri Dec 13, 2013 11:17 am Post subject: |
| That's the most likely problem when all mechanical issues have been ruled out. Sadly, it then becomes a parts machine if you don't have a replacement part on hand. |
Posted: Fri Dec 13, 2013 2:02 pm Post subject: Re: SGT 250 problem |
| prg222 wrote: | | I tried swapping the cartridge from the good player. The same two dashes show up and the arm holding the cartridge does not start to advance, as it does on the other player. |
There is one more thing that is worth checking in to, standing in front of your player, look in the back, right side and there is a belt that advances the stylus arm, it could be broken, or stretched, or if you are lucky, maybe the belt slipped off. Give it a look. _________________ SGT-250
Daxi Don
Posted: Fri Dec 13, 2013 2:49 pm Post subject: SGT250 Problem. |
I assume you are certain that the stylus cartridge is OK. And mechanical problems have been ruled out.
Then the problem is in the signal processing electronics. The most likely
cause is a failure of the Video FM Demodulator chip. Or the 1.53 Mhz clock pulse is missing.
The video modulator chip is IC U3201. The clock pulse will be missing if inductor L3404 has gone open circuit.
You can check for both faults using a common multimeter. On the DC volt range check the voltages on U3201. And on the Resistance range measure the resistance of L3404.
If the parts have to be replaced anyone that can use a soldering iron can do it. Maybe you have a friend who is an electronic hobby person. The parts are available from CEDatum. Your SGT250 seems like a nice player- dont give up on it. |
Posted: Sat Dec 14, 2013 9:18 am Post subject: Re: SGT250 Problem. |
| Daxi Don wrote: | I assume you are certain that the stylus cartridge is OK. And mechanical problems have been ruled out.
gona have to write this down somewhere in my sgt-250 manual for future reference thanks! _________________ (2)Sears 274 & 934(80150,10&11350), sft100, sgt250, sjt 090-400, vp550, VDR3000, VP2000 & 4000
Rich
Posted: Thu Dec 19, 2013 11:21 pm Post subject: SGT250 problem |
I have a problem like this one with my SGT250 . Load disc to player & mounts disc ok - arm is parked at start position .
Then arm motor will run in reverse a few seconds & not move forward .
Then by hand roll the arm motor belt gear that moves worm gear forward a bit - and then it plays ok .
There is a bind at worm gear & gear from arm motor belt gear because of arm motor running in reverse .
I have been through the player - cleaned &/or replaced belts , lubed moving parts - replaced arm motor & 15v regulator -
resoldered places on board the needed it ( like most of it ) & hit all connectors with DeoxIT .
If arm motor is suppost to do this - a solution I will try is to mount an end of stroke swtich w/diode so arm motor will not run in reverse at arm start postion .
If arm motor is not suppost to do this - I hope to find a fix for this one last gremlin .
Thanks to CED forum  |
Posted: Fri Dec 20, 2013 9:50 am Post subject: |
The arm motor isn't supposed to run in reverse upon initial loading of disc, meaning when you pull out the caddy and the disc is ready for play.
It's supposed to actually run forward a little so the stylus can set into place. Sounds like the motor is set up backwards, or reverse polarity. Once it drives itself backward to a certain point, then it cannot continue backward any longer and is binding up and/or quits.
Does the manual advance cause the motor to then operate in normal fashion, or does it just allow playback of several seconds or a minute, then skip backward?
Maybe the motor has an internal problem causing this, or who knows what, but this is what it sounds like, esp a DC motor. Or perhaps your reverse switch or circuitry is defective to the point of causing the motor to engage in reverse right off? |
