Servo Motor Continuously Running SGT-100W
scupbucket
PostPosted: Wed Oct 25, 2023 10:51 pm    Post subject: Servo Motor Continuously Running SGT-100W Reply with quote
Hey gang! I received a new to me sgt100w. It's in really nice shape but I'm stumped with a playback problem. I can't tell if it's mechanical or electrical though. The stylus tested ok with another unit btw. If I load a disc and switch to "play", there's no playback, the display reads "- -", and the servo motor just keeps running, continuously pushing the tonearm backwards. If I switch the unit off and back to play again the motor doesn't run at all. If I switch to "load" and back to "play", the motor keeps on churning in reverse. Its a head scratcher. Would love a little help on this one if possible. Very Happy
lynx
PostPosted: Fri Oct 27, 2023 7:50 am    Post subject: Re: Servo Motor Continuously Running SGT-100W Reply with quote
First of all, congratulations on getting your SGT 100 W CED player. Now, as to your problem, I had the same problem with my CED player a few years ago, which is a model SFT 100 W. It's very similar to your SGT 100 W. I think the problem that you're having is mechanical, and it's an issue with the servo motor drive belt having deteriorated, and the gears needing to be cleaned and lubricated. This motor can be persnickety, and it requires good eye/hand coordination to fix it properly.
Here is a link to a video on cedatum.com showing how to replace the belt and lubricate the gears with common hand tools. It's the last video on the page; just scroll to the end of it.
https://cedatum.com/common-problem/
You can order the belt and washers kit from them, or you can request a free belt from Tom by mail order using the instructions in this link:
http://www.cedmagic.com/home/products.html
Good luck!
Let RCA turn your television into Selectavision!
scupbucket
PostPosted: Fri Oct 27, 2023 2:08 pm    Post subject: Reply with quote
Thanks for the reply, lynx. The servo belt is in very good shape and I disassembled the reduction gear assembly and lubed it up. Ran a bunch of voltage tests and adjusted cams, sensor drum adjust etc. according to the service manual. I also disassembled the turntable and lubed that guy up. I checked all switches and all test functional and are properly adjusted.
Aside from the servo motor constantly running, I also noticed that the stylus is not dropping when the disc is loaded. The "- -" on the display is waiting for a signal. But I'm guessing there isn't the possibility of getting a signal in the first place as the issue of the servo motor running isn't allowing the stylus to drop? I haven't tested the Q16 and Q17 transistors yet for the stylus lifter. I researched the troubleshooting topics in the manual. Unfortunately I don't have a scope to complete some of the more involved tests as I'm starting to think this might be a microcomputer issue?
I was also toying with the possibility of swapping in a new servo arm to see what happens but I don't want to invest in a parts machine just yet. I've done a lot of pinball machine board work so I could try swapping a new IC in but I'm trying to eliminate the easy stuff before I start shotgun replacing parts. I think this unit was barely used and stored well as it's in very nice condition! I'd hate to scrap this one.
scupbucket
PostPosted: Sat Nov 04, 2023 9:35 pm    Post subject: Reply with quote
Made a bit more progress on this. I gave in and bought a parts player. I swapped the arm assembly, nada. But swapping the pw500 board made a huge improvement. The servo motor no longer runs non-stop and I can confirm the stylus drops down onto the disc.
Unfortunately I still have playback problems. The stylus is getting no signal from the disc therefore the servo isnt advancing. The forward and reverse scan and search buttons don't work but pause does. Here's the weird part, and I've only seen it mentioned on the forum a few times. Going back to play after pause results in only one dash... "-" instead of *--*. Very weird and I don't see anywhere in the manual about a single dash problem. I'm thinking I bought a parts player with another bunk board?
scupbucket
PostPosted: Tue Sep 17, 2024 6:30 am    Post subject: Reply with quote
Just adding some closure to this thread... I think the board was indeed bad on my "donor" unit as I bought yet another player for cheap that was beat the frick up, but to my surprise actually worked well... Go figure. So I swapped in all the pretty parts from my original player and frankenstein'd a new unit.
