Weird Sears Player Issue
TGM
PostPosted: Fri Dec 08, 2023 6:06 pm    Post subject: Weird Sears Player Issue Reply with quote
Ive got a Sears 934.54780150 player that skips the movie, goes to the edge of the disc and resets. If I remove the stylus belt, it sorta works: https://www.youtube.com/watch?v=L1kXaGbQIUA
I'm assuming its the belt since it seems to be very loose, but I don't really know, since it still tries to move the arm after I remove the belt. Ive heard there might be a disc sensor that's affected by normal light, but putting the cover on and turning off lights don't make a difference.
Does anyone know what this could be? Thanks!
Glitchy Mario
SJT-100 (not working Sad)
Sears 934.54780150/CED-1 Frankenstein
lynx
PostPosted: Tue Dec 26, 2023 8:38 am    Post subject: Re: Weird Sears Player Issue Reply with quote
Hi Mario.
Sorry for the late reply, but I've been busy with Christmas. Anyway, I watched your video showing your CED player's problem. Since I only own an RCA model SFT 100 W player, I'm not really familiar with any of the less common CED players (Sears, Zenith, Toshiba, Realistic, Montgomery Ward, Hitachi, etc.), but I researched what could be wrong with your player.
I think your players may have bad belts, which you can order from Tom Howe in the mail. This issue is described here on the repair solutions page. Here are two links to the solutions:
http://www.cedmagic.com/tech-info/repair-solutions.html#worn-out-arm-drive-belt-no-playback
http://www.cedmagic.com/tech-info/repair-solutions.html#worn-out-arm-drive-belt-partial-playback
On a side note, the CED that you're playing in the video, Disney's The Love Bug, was one of my favourite childhood movies, and still is today! I have it on CED, and it's still playable, although it's not in the best condition.
Good luck!
Let RCA turn your television into Selectavision!
TGM
PostPosted: Tue Dec 26, 2023 10:02 am    Post subject: Re: Weird Sears Player Issue Reply with quote
Unfortunately, this is a replacement belt. I got it from Josh Gibson, who's belts have worked very well for me in the past, so id like to think it isnt the issue. I emailed him recently, and he said its normally about that loose, so now I am not really suspecting it.
However, you also linked the "Worn Out Arm Drive Belt, No Playback" page which got me thinking that it may be the gearbox. It does look like there may be some gunk or something in it, but I didn't take it into consideration, thinking its just grease. But maybe that worn out grease or gunk is causing enough friction to make the player go all wacky.
Ill go clean the gearbox and re-lubricate it. Ill also clean the pullies even more thoroughly, and I'll keep ya posted.
Glitchy Mario
TGM
PostPosted: Tue Dec 26, 2023 12:52 pm    Post subject: Reply with quote
Unfortunately, it didn't help. It does seem to struggle WAY less getting to the read position, but it is still going to the end without reading. My last idea before going for a smaller belt: I'm gonna accuse my own work.
This player has ATROCIOUS bodge wires and components, which I think is factory original.
I measured out the leads and wire to length and re-soldered them to hopefully make the components not short on a slightest bump of the machine.
Assuming I correctly soldered everything, could the issue be with different resistances or capacitances than the non trimmed mod? Or if I soldered something incorrectly, What component or IC could be affected?
Glitchy Mario
