Would you rather have new discs printed, or have new styli?
Would you rather have:
Newly printed discs with modern titles
16%
 16%  [ 1 ]
New reasonably priced styli
83%
 83%  [ 5 ]
Total Votes : 6
TGM
PostPosted: Tue Apr 16, 2024 5:45 am    Post subject: Would you rather have new discs printed, or have new styli? Reply with quote
If you had to choose between having new discs printed in 2024 with any title you want modern or old, or brand new readily available styli produced at reasonable prices, what would you choose and why?
jjones7
PostPosted: Tue Apr 16, 2024 10:59 am    Post subject: Reply with quote
Dang, that's a tough choice. Since the existing CED catalog is pretty broad, and since most new movies are awful, I'm gonna go with styli.
Still, that's tough since there are many older films I'd love to see on CED - Hammer and Amicus films, later 80s and 90s films, etc.
Tough call.
PostPosted: Fri Apr 19, 2024 8:26 am    Post subject: Reply with quote
I'd def. go with syli,because without new ones eventually no player will work.The only thing I see as difficult is the very tip of the stylus but it seems like if they were originally made 50 years ago or whatever that they could be created today. For the main portion of the cart i see no problem making a real injection mold to create that and I could do that,I've built injection molds for about 30 years and still do general machining. I think it would just be a matter of finding someone who could make the stylus and by now there may be other ways to create the stylus.
PostPosted: Tue May 21, 2024 5:55 pm    Post subject: Reply with quote
New Styli for sure. I've exhausted pretty much every resource regarding rebuilding or new manufacture of styli. Keep in mind RCA spent millions on R&D of styli and their manufacture. There was specialized equipment built, hundreds if not thousands of people employed and they made tens of thousands of styli on a massive industrial scale. They produced enough styli and of sound enough quality that they are still being used by us over 40 years later. Not many products can make that claim. With that said you would think a record stylus is essentially the same thing. But you would be very mistaken. A CED stylus is 40 times smaller than a record stylus. It has to be manufactured to tolerances so extreme that a record stylus manufacturer has told me that it's not even possible today, unless you plan to spend a considerable amount of money, like RCA did. John Stevens told me the company that RCA got their diamonds from is still around today, but a minimum purchase is $12,000. He didn't say how many diamonds that is, could be 100, or could be 1,000, not sure. Either way, I don't have 12k to drop on just the diamond portion of a stylus. After that you have to manufacture the titanium electrotrode that is r/f sputtered onto the diamond which actually reads the disc. While this technology does exist today and there are companies that can do it, the cost of setup and production is extremely high. The a/i tube, ribbon cable, and housing, are probably the cheapest parts and probably only be a couple hundred to manufacture and construct per stylus. When all is said and done, you could build new styli, but it would cost upwards of $1,000 plus per stylus, and that's on a bulk scale even. You would have to drop some serious cash, tens to hundreds of thousands of dollars to be able to remanufacture styli. It's just not cost effective.
But there is an alternative that would be cheaper, but probably not work as well. With modern technology, it would be possible to build a laser that could read the disc and translate the information into the Mhz carrier information that the player can understand. It could be built small enough to fit into the stylus location and attach to the same connectors that the stylus uses. It would have to be battery powered or soldered to a random voltage location on the player for power. This would be a much cheaper and easier option. The only problem with this is discs that are dirty or would typically skip because of the silicone, they might not read very good. Some engineering would have to go into this to make it functional but it's something we could see in the future.
Believe it or not RCA did build optical CED players for the mastering department to verify disc copies. So a lot of the technical information is already out there. It's just a matter of finding a MIT grad in need of a pet project and some proper funding.
TGM
PostPosted: Wed May 22, 2024 10:54 am    Post subject: Reply with quote
My grandpa had suggested the laser idea too. I wouldn’t think it would be too far away from something like a dvd. As for the disc’s imperfections, I believe someone looked into contactless record cleaners, and if that has great results, it may make the laser idea even more feasible. And now that the community knows how to take care of these discs WAY better than back in the day, less discs should be ruined, and with lasers, it won’t touch the disc at all, hopefully preserving the discs even further.
While I also don’t think it’s out of the question someday, it would be cool to see it, even if it takes years and years.
Glitchy Mario
SJT-100 (not working Sad)
Sears 934.54780150/CED-1 Frankenstein
Ced Collector
PostPosted: Mon May 27, 2024 12:09 pm    Post subject: Reply with quote
I voted Newly printed discs. My reasoning is; I've been there, got the t-shirt.
This system was magical back in the day (I loves Toms title to this forum, cus it fits so well.) but it was a poor system. The movies always skipped. Once I became a teen and got a job, I upgraded to a VCR, from the hand me down CED player and stack of movies that my grandparrents gave me and I wont say "I never looked back" because I kept the player and most the movies, that I didn't lose (recently replaced my lost copies) and still watched them from time to time.
I think it's a super cool collectable platform. They're great for display because they're large and their artwork is really cool. They bring back memories from when I was a kid..........But I don't want to watch movies on CED anymore. Not just because they're only standard definition, but because the quality was never really there. It was fine and more than good enough for an 80's kid and someday I'll hook my player up and check it out again for nostalgia's sake. The charm of it all...... But I've no interest in paying any real money to make my player work again, if it ever requires it. Although I have it, and all my movies, none of them have to function anymore.
The joy for me, with the system and the movies, is all in the collecting now. I've already been there and done that, and enjoyed the times when watching the movies this way, was a reasonable, affordable method. It was especially so, when I got a player and movies as a kid.
I'm not sure I would collect too many more modern movies, but I bet I would be interested in some more 80's titles that I wish were released on CED.
For me, they wouldn't even need to be pressed and working CED's. Just new cases (that didn't even open - fake splines) with crisp new labels and seals...That would be pretty cool and would keep cost way down, being they were fake; just collectable, show pieces.
Maybe, the movie could actually be included. How cool would be if someone 3d printed new cases and included the movie inside, on an SD card? Simply plug in a USB cord to it and then plug it into your device. You could watch a modern "HD-CED" collectable.
That's something very doable, someone could do right now. I bet they could make a buck or two. Just an idea. I'd like to see someone run with it. Price and title depending, I could see being a buyer of a few of 'em.
Title suggestion #1 - E.T. The Extra Terrestrial. - 1982
Title suggestion #2 - Halloween 1978 - The first Halloween movie we should have gotten on the platform but didn't.
To avoid trouble, they could come with blank SD cards or even empty SD slots, where the user would install the movie.
and...... would they even have to be 1:1 true scale or just like 1/4 scale to keep cost down? Perhaps both options?
What about 3d printing a working mini CED player? That takes the "HD-SD slot movie CED's"? What if they were printed two sided and held two movies, where you "flip" not for a second half but another movie? The flip would NEED to be incorporated into the system, of course! It's got to keep that charm. That's what would "make" it!
Who's got a 3D printer, looking for a possible side hustle? Wink
My Collections https://ibb.co/album/vCk800
https://ibb.co/album/NrxGtC https://ibb.co/album/0Dmskh https://ibb.co/album/fDYM72
Dude111
PostPosted: Mon Jun 08, 2026 5:05 pm    Post subject: Reply with quote
I think I would rather have a new needle because nothing NEW is most likely gonna be analogue and I would def want analogue on my CED records!!! (LIke they were then)
