Posted: Fri Feb 07, 2014 9:31 am Post subject: New and better transfer rod coupling... |
Hey, guys,
CEDatum has come up with a newly engineered transfer rod coupling that beats the older one by a mile. It's a refined part that still uses the brass pin, but looks better, and is stronger, and has an appearance that matches the original coupling.
This is the part that lifts the transfer rod of the SJT & SKT players, which I often call the disc lift rod, and is connected to the right side gearing assembly. The plastic pin of the part breaks off if the turntable is positioned so that it blocks the lift rod from raising properly.
This is a great part to purchase and have on hand for "just in case" use. |
Posted: Fri Feb 07, 2014 12:44 pm Post subject: |
I remember telling you about these when you were showing how to drill out the old stem, maybe I am thinking wrong :/ Either way you are correct!! The transfer rod coupling is cedatum makes are strong as hell! _________________ I dont own
Posted: Fri Feb 07, 2014 2:57 pm Post subject: |
The old coupling they had eventually got brittle or something, so they got a new product made from another material. I had three of the old ones, and the tension of the rod spring itself was enough to break two of them before I stopped.
They had very few left in stock apparently and discovered that those were brittle as well. Then remodeled, redesigned a new one that is really great and it's appearance is just right. It looks like a stock part except for the brass pin. |
Posted: Fri Feb 07, 2014 3:21 pm Post subject: |
I never said it, but when I did talk about them they were the new kind with the brass stem and molded plastic part that actually grabs the disc transfer rod. I always forget something haha! I can remember cedatum showing them to me at one of the workshops!
http://www.cedmagic.com/forum/viewtopic.php?t=1913&highlight=transfer+coupling+rod _________________ I dont own
Posted: Fri Feb 07, 2014 10:27 pm Post subject: |
Yes, but that was the still old version of the replacement part. It had a partly translucent molded part. That molded part eventually became brittle.
The new one is one they just came up with in the last few weeks and sent me a few to test out. It actually has a much better molded part that is much more refined and with sharper details and looks like the original part, and is the right color as well. |
Posted: Fri Feb 07, 2014 10:35 pm Post subject: |
Yep that sounds different! _________________ I dont own
Posted: Fri Feb 28, 2014 8:54 pm Post subject: |
Does this show the old and new transfer rod coupling rix?
Posted: Sat Mar 01, 2014 2:26 am Post subject: |
That is nice that there is a new coupling.
However:
HOW DO YOU REPLACE THE OLD COUPLING WITH A NEW ONE????? _________________ Sears 934.54780150 & 934.54810350
Posted: Sat Mar 01, 2014 7:32 am Post subject: |
| blindfury420 wrote: | Does this show the old and new transfer rod coupling rix?
it looks like they re both next to each other to the right of the chip? _________________ (2)Sears 274 & 934(80150,10&11350), sft100, sgt250, sjt 090-400, vp550, VDR3000, VP2000 & 4000
Posted: Sat Mar 01, 2014 9:50 am Post subject: |
I know the brownish looking one is the old one. I assume the newer one is the one above it that has the original color. _________________ I dont own
Posted: Sat Mar 01, 2014 1:09 pm Post subject: |
The new one is that one above, as you thought. See how much finer it is and a beter match to the original.
You don't need to replace the old one with a new one unless the old one breaks. If that happens, then the replacement is pretty easy because you then have room to maneuver. |
