Gunner
Joined: 09 Dec 2012 Posts: 80 Location: Toronto, Canada
Posted: Sat Feb 01, 2014 5:09 am Post subject: Mono Players vs Stereo Players |
| So one small issue I have been having as of late is trying to find a way to play certain mono players on my modern tv. The main issue is that I have 2 players (an SFT 100 and an SJT 90) that will not play properly on my modern tv. Both players do not have RCA style video jack ports but instead work on the old coax style screw in cable. I have found that all my other players (mostly stereo) that work off the RCA style cables (red, yellow, white) work perfectly on the modern televisions but these two players for whatever reason just show a skipping pictue when hooked up. When I hook these 2 players up to an old tv, they work perfectly. Has anyone else experienced this or have any insight? Just curious.... |
Posted: Sat Feb 01, 2014 10:17 am Post subject: |
i believe you can get an signal booster that will convert coax to rca there was a discussion about this before but i cant find the details, there a re a few in here that can chime in on this im sure _________________ (2)Sears 274 & 934(80150,10&11350), sft100, sgt250, sjt 090-400, vp550, VDR3000, VP2000 & 4000
Daxi Don
Posted: Sat Feb 01, 2014 3:04 pm Post subject: AV connectors for RCA CED players with only CH3/4 output |
| CEDatum designed a kit to add a Video and Mono audio RCA connectors to RCA CED players that only provide a Ch3/4 coax output . The modification consists of module installed in the player and RCA connectors added to the back panel of the player. The mod provides superior performance to any external coax booster or signal processor. The most recent build of the AV module was made by BlindFury. He can install the kit. |
Posted: Sat Feb 01, 2014 3:16 pm Post subject: |
Don't you have a VCR still? _________________ A New Vista of RCA Victor COLOR! |
Posted: Sat Feb 01, 2014 3:26 pm Post subject: |
Does it do this? http://www.youtube.com/watch?v=mOLzhneOTV0 _________________ I dont own
Posted: Mon Feb 03, 2014 7:49 am Post subject: |
WHat you describe is a common issue with CED players, especially those with only RF out. Even the AV output will have this same problem on some newer TV sets.
I use a Hitachi AVC unit to convert the signal from analog to digital HDMI. It can also convert both analog RF channel 3 or 4 or AV output. This solved the problem of weak signal and its effect.
Our other two sets are CRT, so no problem with them. |
Posted: Mon Feb 03, 2014 12:25 pm Post subject: |
All of my sets are analog and I have three CRT projectors. My problems have all been with the Extron VGA converter I wanted to send the computer video out to the TVs with and project it...I ended up with a double image on the computer's CRT monitor at the time and took it off for fear of damaging the computer's video. _________________ A New Vista of RCA Victor COLOR! |
Posted: Mon Feb 03, 2014 12:34 pm Post subject: |
Every pc of my own, that I built since 2004 has been connected to one to two tv's! I used to use s-video from the back of the video card to the tv, Then just run sound to whatever receiver I had. It's way easier now because most video cards have hdmi or display ports out. Letting you connect to newer lcd and led tv's. While still having 2 dvi outs. Still wouldn't help your crt connection problem though :/ _________________ I dont own
Posted: Mon Feb 03, 2014 1:33 pm Post subject: |
This is a Dell Dimension 2350 and as such is a piece of junk and I couldn't get an ATI Radeon 9250 PCI going on it (BIOS doesn't seem to even be much help), no AGP of course, no PCI-e and I'm trying to get video on my Asus with dual SLI and quadcore AMD 939 but I tried to redo it to get the endless wiring down and the LEDs out that were in the case and only advertised it in the window in a bad neighborhood...
Needless to say I think I flummoxed the GeForce 7800. _________________ A New Vista of RCA Victor COLOR! |
Dude111
Posted: Wed Apr 09, 2014 6:30 pm Post subject: |
I am seriously considering getting an SFT-100,those are MONO right??
I did see one disturbing thing when I was @ my friends place today that has a bunch of videodiscs for sale!
On the movie "GONE WITH THE WIND" it says "Digitally enhanced for stereo" -- Kind of upsetting,you wont get true analogue sound from this wonderful movie EVEN ON VIDEODISC (Unless there is a MONO copy of this movie out there)
I saw alot of other movies also,thankfully none of them had anything about digital!!
Poltergiest
Rocky
Those 2 I would most likely get if I could get myself an SFT-100! |
Posted: Wed Apr 09, 2014 11:38 pm Post subject: |
Yes, mono. They aren't bad, if you want stereo you have to look for the SGT 200/250 etc. _________________ A New Vista of RCA Victor COLOR! |
Dude111
Posted: Fri Apr 11, 2014 8:41 pm Post subject: |
Muchos Gracious.......... I think this is wonderful technology  |
Mayor West
Joined: 22 Mar 2014 Posts: 66 Location: Quahog, Rhode Island
Posted: Sat Apr 12, 2014 9:17 am Post subject: |
| kitchensynch wrote: | | I ended up with a double image on the computer's CRT monitor at the time and took it off for fear of damaging the computer's video. |
Did you ever get this resolved? I had to really dumb down my video card settings when I used to connect to CRT monitors or sets. Hertz and the refresh rate needed the most adjustment, also pixel depth and size. Sorry if I am preaching to the band, it just helped me out.  |
Posted: Sat Apr 12, 2014 11:11 am Post subject: |
I haven't gotten back to either of them but I also have S-video outputs on a couple of my computers and I can patch them into my RF modulator switchers. _________________ A New Vista of RCA Victor COLOR! |
Pacattack76
Posted: Sun Jun 08, 2014 1:24 pm Post subject: |
| I have the RCA SJT-090 and its mono. Couldn't ask for better. And no issues either since i have it hooked to a 1984 RCA XL-100 25" console with mono sound. |
Pacattack76
Posted: Sun Jun 08, 2014 1:25 pm Post subject: |
jeff7624
Joined: 23 Feb 2014 Posts: 38 Location: United States
Posted: Wed Jun 11, 2014 6:33 pm Post subject: |
| If it was me I would go hit Goodwill or some other thrift store. They usually have piles of the coax to rca converters for sale. I saw one a couple weeks ago still in the box for $5. I used to have a couple for video games but they are long gone or I'd offer it to you. |
Posted: Wed Jun 11, 2014 11:30 pm Post subject: |
I've got a friend I'll be getting one of two stereo players from at some point this year...after the vintage Pioneer cassette deck, analog tuner and reel to reel and a receiver (hey, it's my birthday this month).
I already have autoswitching 4-input RF modulators. |
