mistercates
Posted: Wed Jan 28, 2015 10:21 pm Post subject: RCA sgt 250 yard sale find disc stuck in machine flashing L |
| I'm new to the group and to CED's, I picked up a RCA SGT250 with 31 discs for $10 at a yard sale. There is a Heaven Can Wait disc stuck in the player. When I plug it up the display flashes L and none of the buttons work. I took the cover off but can't tell anything about it. Any ideas? Any help is appreciated! |
Glen M
Posted: Sat Jan 31, 2015 1:39 am Post subject: |
| I'm new to CED myself but may I suggest it sounds like one or more belts are slipping or broken. My PAL player had a similar issue in that it wouldn't lift the tray. There were two issues in that the belt at the motor that controls the arm position had broken so the arm could not reset home. Then there was the issue that the belt from the motor that lifts the motor was stretch and slipping. Once both where replaced it all worked again. |
mistercates
Posted: Fri Feb 06, 2015 6:58 pm Post subject: |
| When you had the problem with the belts could you hear the motor spinning? My player makes no sounds at all. The disc is still in the case and stuck in the player. Im just wondering if it may be one of the boards that is bad. |
Posted: Sat Feb 07, 2015 12:40 pm Post subject: |
Most likely to be a belt or other mechanical problem. _________________ A New Vista of RCA Victor COLOR! |
mrlousi7
Posted: Fri Feb 20, 2015 6:38 am Post subject: |
This movie was made in the early 80's with Charlie Sheen, Sherilynn Fenn , Randy Quaid, John Casavettes, etc. _________________ SAJDI33 |
mistercates
Posted: Tue Sep 22, 2015 12:35 pm Post subject: |
| mrlousi7 wrote: | | This movie was made in the early 80's with Charlie Sheen, Sherilynn Fenn , Randy Quaid, John Casavettes, etc. |
Which movie are you talking about? |
