Alex S
Posted: Wed Aug 17, 2016 4:50 pm Post subject: Sgt 250. Shaky image |
My newer SGT has a shaky image right left shake the picture is clear but it just shakes back and forth kinda quickly. Anyone ever come across this ?
Thx
Alex |
Posted: Thu Aug 18, 2016 10:10 pm Post subject: |
Platform instability? Poorly centered disc or damage to the spindle hole or clamping mechanism? Have you removed the lid while playing it?
Is the power supply also stable and that to the motor? _________________ A New Vista of RCA Victor COLOR! |
Daxi Don
Posted: Fri Aug 19, 2016 5:59 am Post subject: SGT250 Shaky Image |
[Shaky image, back and forth movement. Good chance that you player Time-Base Correction is not working. On your player check the following:
1/ Remove the stylus arm multipin connector. Measure the resistance between pins 10 and 11 . It should be approx. 35 ohms.
2/ Remove the stylus. The back end of the stylus connects with the armstretcher coil using a magnetic latch. The coil plunger end has a black magnetic button. Check that the button is in place - it can come off if the glue is weak. |
