harrison_bassist
Posted: Fri Dec 09, 2005 11:08 pm Post subject: my Zenith VP2000 has no picture. please help |
hello i have Zenith VP2000 CED player that does not disply picture and the readout does not change to 0 or 1. inside is mint shape. it speeds up quietly and smooth. the stylus does apper to be tracking but not sure if its working. any help is much appreciated.
mike |
Posted: Wed Dec 14, 2005 5:02 pm Post subject: RE: Zenith VP2000 - No Playback at Startup |
Mike:
After loading a disc, turn the function lever to OFF, then by hand through the access cover, move the pickup arm inward so the stylus tip is approximately over the center of the grooved surface of the disc. Now move the function lever to PLAY and observe if playback ensues. If it does, you have an improper stylus set down adjustment, which can be corrected by the procedure on this page:
http://www.cedmagic.com/tech-info/repair-solutions.html#improper-stylus-set-down-adjustment
If the above test does not result in playback, the next procedure to try is stylus cartridge substitution, but you need a known-good stylus cartridge for that.
harrison_bassist
Posted: Tue Jan 03, 2006 1:13 am Post subject: |
I tried the set down adjustment and checked the stylus, its in good shape. whats next. IC chip corrupt? still reads "--"
and if i press pause and and play it will say "- " |
Posted: Fri Jan 06, 2006 12:28 pm Post subject: RE: VP2000 Startup Problem |
The change in the LED display from "--" to "-" indicates a system control problem, as that display should not change until a signal is recovered from the disc. Try loading a disc with the stylus cartridge removed and the stylus cover open. When the function lever is moved to play, the stylus lifter rod inside the stylus cartridge cavity should descend a few seconds after the disc spins up. If it does not, you definitely have a system control problem.
Fixing this will require some circuit analysis, which can be accomplished either with a scope, or by measuring the voltage at circuit nodes on the system control board sitting above the turnable.
Guest
Posted: Fri Jan 06, 2006 4:20 pm Post subject: |
| the stylus lifting rod works perfect. if theres nothing else to check, then ill take it to a repair shop. though i dont want to, it ill be very expensive |
Reinhart
Posted: Sat Jan 07, 2006 4:25 pm Post subject: |
Please remember that your Zenith VP-2000 is actually a rebadged RCA SFT-100W. Some of the SYSCON and DAXI components essentially remained unchanged from the SFT-100W all the way up to the prototype Dimensia SKT-425.
Another thing you could do is simply get another player. If you score another VP-2000 or get an SFT-100W, your current player becomes an instant source of spare parts in case you need them.
If it's a SYSCON problem, it may require replacement of any of the control ICs. Those may not be available for replacement unless you can procure a salvaged player with good electronics. Or, you can check out CEDatum for any available parts and service information:
http://www.ccrtc.com/technology/cedatum/
This was what I ended up doing when I was restoring an SGT-250. I had two of these machines which were given to me by an electronics repair shop I worked at (they were donated to the shop and were about to be thrown out), but one had a faulty DAXI microcomputer while both had a bad stereo processing module and, of course, the player required new rubber.
The one with the good DAXI processor had a bad exterior while the other looked almost mint, so I swapped the chips. Then, I ordered a new set of rubber and a replacement stereo module from CEDatum and then procured the correct replacement remote from eBay. When I got a functioning SGT-250 with the remote, my SJT-200 ended up in my closet as a spare. - Reinhart |
harrison_bassist
Posted: Wed Jan 11, 2006 2:33 am Post subject: |
| Id just like to say Thank You to Tom and Reinhart for all the help i recieved so far. |
harrison_bassist
Posted: Fri Jan 13, 2006 5:58 pm Post subject: |
thanks for the help.
if you can, please list the possible chips/processors that may be malfuntioning. names and/or numbers. so i can test them.
thanks
Mike G. |
harrison_bassist
Posted: Sun Jan 15, 2006 1:05 pm Post subject: i tested the DAXI |
hello
i tested the DAXI buffer (U503) and came up with tese results on a DC voltmeter. do these results mean a corrupt DAXI?
PIN #----------LOAD/UNLOAD------------PLAY-----------------PAUSE
1------------------ 2.61v------------------2.60v----------------2.61v
2--------------------0-----------------------0----------------------0
3------------------2.48v------------------2.48v-----------------2.48v
4-------------------0------------------------0--------------------0.01v
5-------------------0----------------------0.01v-------------------0
6-----------------2.52v-------------------2.51v-----------------2.52v
7------------------0-------------------------0----------------------0
8------------------0-------------------------0----------------------0
9------------------0-------------------------0----------------------0
10---------------0.03v--------------------0.03v-----------------0.03v
11---------------0.03v--------------------5.06v-----------------0.03v
12----------------0------------------------2.63v------------------0
13----------------0------------------------0.01v------------------0
14--------------5.24v---------------------5.22v-----------------5.23v |
Smoky Pond
Joined: 31 Dec 2005 Posts: 20 Location: Oakland Township, MI
Posted: Sun Jan 15, 2006 5:30 pm Post subject: |
Let's step back a bit on this one.
Are you sure the stylus is OK?
How did you check it? Visually or with a microscope? If by microscope, what was the magnification? I find that I need at least 200X to see enough detail to tell if the stylus is even usable.
The best test is a swap with a known good.
Matt _________________ "Born after my time!"
Smoky Pond Farm Website |
